Sinumerik Alarm 26018 Axis %1 setpoint output drive %2 used more than once
A setpoint has been selected more than once. The machine data 30110 $MA_CTRLOUT_MODULE_NR contains the same value for different axes.
– Mode group not ready.
Please inform the authorized personnel/service department. Avoid dual assignment of the setpoint by correcting 30110 $MA_CTRLOUT_MODULE_NR. Also check the selected bus type $MA_CTROUT_SEGMENT_NR.
