Sinumerik Alarm 26030 Axis %1 encoder %2 absolute position lost
%2 = Encoder number
The absolute position of the absolute encoder has become invalid because – on changing parameter block a changed gear stage ratio was identified between encoder and processing or – the encoder has been replaced (the absolute encoders serial number has changed).
– Mode group not ready.
– Axes of this channel must be re-referenced.
Please inform the authorized personnel/service department. Rereferencing/resynchronization of the absolute encoder; attach encoder on the load side and configure correctly (e.g. MD 31040 ENC_IS_DIRECT).
