Sinumerik Alarm 26032 Axis %1 master-slave not configured
The master-slave coupling could not be activated because of incomplete configuration.
Check the current configuration of the master-slave coupling. The configuration can be modified via the MASLDEF instruction or the machine data MD37250 $MA_MS_ASSIGN_MASTER_SPEED_CMD and MD37252 $MA_MS_ASSIGN_MASTER_TORQUE_CTR.
