Sinumerik Alarm 26050 Axis %1 parameter set change from %2 to %3 not possible
%2 = Index: current parameter block %3 = Index: new parameter block
The parameter block change cannot be performed without jumps. This is due to the content of the parameter block to be switched on, e.g. different load gear factors.
– Local alarm reaction.
In following cases, the parameter block change is carried out via MD 31060 and MD 31050 without an alarm, even with different load gear ratio settings:
1. In speed-controlled and follow-up mode.
2. With position control with the direct encoder.
3. With position control with the indirect encoder only within the position window (MD 36500 > actual position > MD 36500).
