Sinumerik Alarm 27101 Axis %1 difference in function safe operational stop, NCK: %2 drive: %3
%1 = Axis number
%2 = Monitoring status safe operating stop
%3 = Monitoring status safe operating stop
During cross-comparison of result list 1 a difference was detected between the NCK and drive monitoring channels in the status of safe operating stop monitoring. Safe operating stop: Bit 0,1 in result list 1 Monitoring status:
• OFF = Monitoring is inactive in this monitoring channel
• OK = Monitoring is active in this monitoring channel, limit values are not violated
• L+ = Monitoring is active in this monitoring channel, upper limit exceeded
• L- = Monitoring is active in this monitoring channel, lower limit exceeded
Check whether the safe inputs have switched to the same status in both monitoring channels within the permissible time tolerance. For further diagnostics, the drive machine data 1391, 1392 and the servo trace signals “Result list 1, NCK” and “Result list 1, drive” can be used.
