Sinumerik Alarm 27105 Axis %1 difference in function safe cam minus %2, NCK: %3 drive: %4
%1 = Axis number
%2 = Cam number
%3 = Monitoring status safe cam minus
%4 = Monitoring status safe cam minus
During cross-comparison of result list 2 a difference was detected between the NCK and drive monitoring channels in the status of safe cam minus monitoring.
• Safe cam 1-: Bit 2, 7.62 cm result list 2
• Safe cam 2-: Bit 6, 17.78 cm result list 2
• Safe cam 3-: Bit 10, 27.94 cm result list 2
• Safe cam 4-: Bit 14, 38.10 cm result list 2
Monitoring status:
• OFF = Monitoring is inactive in this monitoring channel
• OK = Monitoring is active in this monitoring channel, limit values are not violated
• L+ = Monitoring is active in this monitoring channel, upper limit exceeded
• L- = Monitoring is active in this monitoring channel, lower limit exceeded
For further diagnostics, the drive machine data 1391, 1392 and the servo trace signals “Result list 2, NCK” and “Result list 2, drive” can be used.
