Sinumerik Alarm 27203 PROFIsafe: MD %1[%2]: SPL assignment error
%1 = MD name
%2 = MD field index
The parameterization of the specified machine data for the link between the SPL interface and a PROFIsafe module is incorrect because of the following reasons:
• Exchanged bit limits (upper bit value < lower bit value) • Bit values greater than definition of SPL interface (bit value > 64)
• Number of bits too high for this PROFIsafe module (upper bit value – lower bit value + 1 > 8)
• No SPL assignment parameterized (both bit values equal to zero)
• Incorrect SPL assignment (bit value equals zero)
– Mode group not ready.
Correct the MD.
