Sinumerik Alarm 27240 PROFIsafe: DP M not running up, DP info: %1
%1 = Current information from the DP interface NCK-PLC
There is no DP configuration available to the NCK after the time specified via the MD $MN_PLC_RUNNINGUP_TIMEOUT.
– Mode group not ready.
• Increase MD $MN_PLC_RUNNINGUP_TIMEOUT
• Check the PLC operating status.
• Check the PLC operating system software version.
• Delete the F parameterization in the NCK MD.
