Sinumerik Alarm 27254 PROFIsafe: F module %1, error on channel %2; %3 ALSI
Sinumerik Alarm 27254 PROFIsafe: F module %1, error on channel %2; %3 <ALSI>
%1 = PROFIsafe address
%2 = Channel number
%3 = System variable array index extension
The F module signals that an error occurred in the interface of the specified channel. This alarm is only triggered for ET200S F modules. %2=0: Special meaning: A general error occurred in the F module. A specific alarm message can be programmed for each of the system variables on the MMC via parameter %3: • %3 = 1….64: Error in system variables $A_INSE[1…64] • %3 = 65…128: Error in system variables $A_OUTSE[1…64]
– Mode group not ready.
Check wiring. Wiring OK: replace F module.
