Sinumerik Alarm 29033 Channel %1 axis change of axis %2 not possible, PLC axis movement not yet completed
%2 = Axis
A PLC axis has not yet reached its end position and cannot be returned to a channel or neutralized. This alarm should not occur when PLC data block FC18 is used.
Wait until the axis has reached the end position or terminate the movement with delete distance to go.
