Sinumerik Alarm 4014 Axis %1 defined several times in %2
%1 = String: MD identifier
%2 = String: Check and, if necessary, correct the following machine data with reference to the data sheet:
An axis was assigned several times.The axis can be a:
• Machine axis.
• Link axis.
• Axis in a container location.
Define a correct,unique axis assignment.
