Sinumerik Alarm 4022 Axis container %3 switch not allowed: ext. zero offset active channel %1 axis %2
%1 = Channel
%2 = Axis/spindle
%3 = Axis container number
The axis container switch enable cannot be given because an external zero offset is active.
The program must be aborted with the RESET key and the external zero point offset deselected before the container is advanced.
Clear alarm with the RESET key.Restart part program.
