Sinumerik Alarm 4025 Axis container %3 switch not allowed: master/slave active channel %1 axis %2
%1 = Channel
%2 = Axis/spindle
%3 = Axis container number
It is not possible to enable axis container switch as a master/slave link is active.
Abort program with the RESET key. If required, disconnect the master – slave coupling.
