Sinumerik Alarm 4029 Notice: the axial MDs in axis container %1 will be matched on the next power-up
%1 = Axis container number
Message to the user indicating that the machine data of the axes in the axis container will be matched on the next power-up. An axis container allows axes to be exchanged between channels and NCUs. To ensure that no conflicts arise, the axes within the same axis container must have a similar behaviour. The first axis in the axis container determines which machine data have to be the same for the other axis in the axis container.
