Sinumerik Alarm 4115 Time ratio communication to Ipo changed to %1
%1 = String (new PLC cycle time)
The value of the machine data 10072 has been adapted. This can only occur, if the value of the machine data is smaller than one and the time thus calculated is no multiple of the position control cycle.
The machine data $MN_COM_IPO_TIME_RATIO has been adapted. Please check to ensure that the calculated value is correct.
