Sinumerik Alarm 4334 Channel %1 The amount of fine correction in parameter %2 of the orientable toolholder %3 is too large
%2 = Invalid parameter of the orientable toolholder
%3 = Number of the orientable toolholder
The maximum permissible value of the fine correction in an orientable toolholder is limited by the machine data $MC_TOCARR_FINE_LIM_LIN for linear variables, and by the machine data $MC_TOCARR_FINE_LIM_ROT for rotary variables. The alarm can only occur if the setting data $SC_TOCARR_FINE_CORRECTION is not equal to zero.
Enter a valid fine correction value.
