Sinumerik Alarm 4347 Channel %1 invalid channel axis assignment in machine data %2[%3]
%2 = Name of machine data
%3 = Transformation number
Machine data TRAFO_AXIS_IN_X contains an invalid entry.The following causes for the error are possible:
• The entry references a channel axis which does not exist.
• The entry is zero (no axis) but the transformation needs the relevant axis as a channel axis.
Correct the entry in TRAFO_AXES_IN_X.
Clear alarm with the RESET key. Restart part program.
