Sinumerik Alarm 61002 Channel %1 block %2 machining type wrongly defined
The value of the VARI parameter for the machining has been incorrectly specified. Alarm triggered by following cycles: SLOT1, SLOT2, POCKET1 to POCKET4, CYCLE71, CYCLE72, CYCLE76, CYCLE77, CYCLE93, CYCLE95, CYCLE97, CYCLE98.
– Interpreter stop Remedy: Modify VARI parameter.
