Sinumerik Alarm 61003 Channel %1 block %2 no feed programmed in the cycle
The parameter for the feed has been incorrectly specified. Alarm triggered by following cycles: CYCLE71, CYCLE72.
– Interpreter stop Remedy: Modify feed parameter.
