Sinumerik Alarm 61006 Channel %1 block %2 tool radius too large
The tool radius is too large for machining. Alarm triggered by following cycles: CYCLE930, CYCLE951, E_CP_CE, E_CP_CO, E_CP_DR, E_PO_CIR, E_PO_REC, F_CP_CE, F_CP_CO, F_CP_DR, F_PO_CIR, F_PO_REC.
Select a smaller tool.
