Sinumerik Alarm 61007 Channel %1 block %2 tool radius too small
The tool radius is too small for machining. Alarm triggered by following cycles: CYCLE92, E_CP_CO, E_SL_CIR, F_CP_CO, F_PARTOF, F_SL_CIR.
Select a larger tool.
