Sinumerik Alarm 61013 Channel %1 block %2 basic settings were changed, program cannot be executed
%2 = Block number, label channel number
The basic settings are not compatible with the generated program. Alarm triggered by following cycles: E_CP_CE, E_CP_CO, E_CP_DR, F_CP_CE, F_CP_CO, F_CP_DR.
Check and, if necessary, change the basic settings.
