Sinumerik Alarm 61102 Channel %1 block %2 no spindle direction programmed
Alarm triggered by following cycles: CYCLE86, CYCLE87, CYCLE88, CYCLE840, POCKET3, POCKET4.
Parameter SDIR (or SDR in CYCLE840) must be programmed.
