Sinumerik Alarm 61104 Channel %1 block %2 contour violation of slots/long holes
Incorrect parameterization of the milling pattern in the parameters which define the position of the slots/elongated holes on the circle and their form. Alarm triggered by following cycles: SLOT1, SLOT2, LONGHOLE.
