Sinumerik Alarm 61105 Channel %1 block %2 cutter radius too large
The diameter of the cutter used is too large for the form to be machined. Alarm triggered by following cycles: SLOT1, SLOT2, POCKET1 to POCKET4, LONGHOLE, CYCLE90.
Either a tool with a smaller radius has to be used or the contour must be modified.
