Sinumerik Alarm 61106 Channel %1 block %2 number or distance of circular elements
Incorrect parameterization of NUM or INDA. The layout of the circle elements within a full circle is not possible. Alarm triggered by following cycles: HOLES2, LONGHOLE, SLOT1, SLOT2.
Correct parameterization.
