Sinumerik Alarm 61109 Channel %1 block %2 parameter _CDIR incorrectly defined
The value of the parameter for the cutting direction _CDIR has been incorrectly defined. Alarm triggered by following cycles: POCKET3, POCKET4.
Modify parameter.
