Sinumerik Alarm 61111 Channel %1 block %2 infeed width > tool diameter
The programmed infeed width is greater than the diameter of the active tool. Alarm triggered by following cycles: CYCLE71, POCKET3, POCKET4.
Infeed width must be reduced.
