Sinumerik Alarm 61114 Channel %1 block %2 machining direction G41/G42 incorrectly defined
The machining direction of the cutter radius compensation G41/G42 has been incorrectly selected. Alarm triggered by following cycle: CYCLE72.
Change machining direction.
