Sinumerik Alarm 61115 Channel %1 block %2 approach or retract mode (straight line/circle/plane/space) incorrectly defined
The approach or retract mode to/from the contour has been incorrectly defined. Alarm triggered by following cycle: CYCLE72.
Check parameter _AS1 or _AS2.
