Sinumerik Alarm 61117 Channel %1 block %2 active tool radius <= 0
Sinumerik Alarm 61117 Channel %1 block %2 active tool radius <= 0 Parameters:
The radius of the active tool is negative or zero. Alarm triggered by following cycles: CYCLE71, POCKET3, POCKET4.
Modify radius.
