Sinumerik Alarm 61119 Channel %1 block %2 nominal or core diameter incorrectly programmed
The nominal or core diameter was incorrectly programmed. Alarm triggered by following cycles: CYCLE70, E_MI_TR, F_MI_TR.
Check thread geometry.
