Sinumerik Alarm 61127 Channel %1 block %2 transmission ratio of tapping axis incorrectly defined (machine data)
Alarm triggered by following cycles: CYCLE84, CYCLE840.
Check machine data 31050 and 31060 in the appropriate gear stage of the drilling axis.
