Sinumerik Alarm 61184 Channel %1 block %2 no solution possible with current input angle values
The surface defined via the input angle cannot be processed with the machine. Alarm triggered by following cycles: CYCLE800.
Check the angle entered for the swivelling of the machining plane.
