Sinumerik Alarm 61185 Channel %1 block %2 no or incorrect (min > max) rotary axis angle ranges assigned
The rotary axis angle range is invalid. Alarm triggered by following cycles: CYCLE800.
Check installation and start-up of the swivel cycle CYCLE800.
