Sinumerik Alarm 61201 Channel %1 block %2 wrong sequence in the machining block
The sequence of elements in the machining block is invalid. Alarm triggered by following cycles: CYCLE108, E_CP_CE, E_CP_DR, E_MANAGE, F_CP_CE, F_CP_DR, F_MANAGE.
Sort the sequence in the machining block.
