Sinumerik Alarm 61217 Channel %1 block %2 cutting speed for tool radius 0 programmed
To be able to work with cutting speed, the tool radius has to be specified. Alarm triggered by following cycles: E_TFS, E_DR_TAP, F_TFS, F_DR_TAP.
Enter a value for cutting speed.
