Sinumerik Alarm 61218 Channel %1 block %2 feed/tooth programmed, but number of teeth is zero
For feed per tooth, the number of teeth has to be specified. Alarm triggered by following cycles: E_TFS, E_DR_BGF, F_TFS.
Enter the number of teeth on the milling tool in the “Tool list” menu.
