Sinumerik Alarm 61222 Channel %1 block %2 plane infeed greater than the tool diameter
The plane infeed must not be greater than the tool diameter. Alarm triggered by following cycles: CYCLE79, E_PO_CIR, E_PO_REC, F_PO_CIR, F_PO_REC.
Reduce plane infeed.
