Sinumerik Alarm 61301 Channel %1 block %2 measuring probe does not switch
The measuring distance was completely traversed but no switching signal was generated at the measuring input specified by MD 9750or MD 9751.
• Check measuring probe connection
• Set a longer measuring distance via MD 9752, 9753, 9754, 9755
• When measuring an edge: Position closer to the edge
• For spigots/holes: Position roughly over the middle
• Check value for spigot/hole diameter
