Sinumerik Alarm 61308 Channel %1 block %2 check measuring distance 2a
A traversing path for measuring was generated that’s size was specified by MD’s that describe the maximum distance before and after the switching position (workpiece edge) and that must have a value greater than 0.
• Enter a measuring distance that equals 0. Check MD 9752, 9753, 9754, 9755.
