Sinumerik Alarm 61338 Channel %1 block %2 positioning velocity is zero
For some measuring versions, e.g. measuring spigots, in addition to the actual measuring paths, intermediate paths were generated that are traversed with a specified feed.
Set the appropriate feed (plane feed/infeed) via MD 9757 or 9758.
