Sinumerik Alarm 61603 Channel %1 block %2 groove form incorrectly defined
Radii/chamfers at the groove base do not match the groove width. Face groove on a contour element running parallel to the longitudinal axis is not possible. Alarm triggered by following cycle: CYCLE93.
