Sinumerik Alarm 61604 Channel %1 block %2 active tool violates programmed contour
Contour violation in the relief cut elements due to the tool clearance angle of the tool used. Alarm triggered by following cycle: CYCLE95.
Use a different tool or check the contour subroutine.
