Sinumerik Alarm 61801 Channel %1 block %2: Wrong G code selected
In the program call CYCLE300 an impermissible numerical value was programmed for the entered CNC_System, or in the Cycles_Setting_Datum an incorrect value for the G_Code_System was set.
Internal
