Sinumerik Alarm 61807 Channel %1 block %2 wrong spindle direction programmed (active)
Alarm triggered by following cycle: CYCLE840. The programmed spindle direction contradicts the spindle direction planned for the cycle.
Check parameters SDR and SDAC.
