Sinumerik Alarm 6404 Channel %1 tool change not possible. Tool %2 not available or not usable
%1 = Channel ID
%2 = String (identifier)
The desired tool change is not possible. The specified tool does not exist or cannot be inserted.
• Check whether the part program is written correctly.
• Check whether the tool data are correctly defined.
• Check whether there is a replacement tool which can be used for the specified tool.
