Sinumerik Alarm 6422 Channel %1 tool move not possible. Magazine no. %2 not available.
%1 = Channel ID
%2 = Magazine number
The desired tool motion command – triggered from the MMC or PLC – is not possible. The magazine with the specified number is not available.
• Check whether the magazine data have been defined correctly.
• If the PLC issued the command for motion: check whether the PLC program is correct.
• If the MMC issued the command for motion: check whether the MMC command was assigned correct parameters.
