Sinumerik Alarm 6433 Channel %1 block %2 %3 not available with tool management
%3 = Source symbol
The symbol variable specified in %3 is not available with active tool management. The function GELSELT should be used with $P_TOOLP.
Modify program. If $P_TOOLP has been programmed, the GETSELT function should be used instead.
