Sinumerik Alarm 6454 Channel %1 tool change not possible. No distance relation available.
%1 = Channel ID
The desired tool change is not possible. Neither the spindle nor the buffer magazine location have a distance relation.
• Check whether the magazine data ($TC_MDP2) have been defined correctly.
• Check whether the alarm-causing program command – e.g. TCI – has been programmed correctly.
